955
Error Grid !!! i dont know what happend
i get an error when i Bind an WebDataGrid,  this WebDataGrid fills with a dataset .. this dataset provides a property called Detalle, but when i rebind many times with a new DataSet,   the application fails and display this error.
DataBinding: 'Infragistics.Web.UI.GridControls.GridRecordItem' does not contain a property with the name 'Detalle'
Below my code ASPX.. anybody knows what happen here?
ASPX Code:
visible='<%# esVisible((DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Detalle"))%>'
CS code:
private bool esVisible(object isVisible)
            if ((int)isVisible == 1)
                return true;
            return false;
Regards.
Alfredo Melo xD
PD. the application works fine, but after of many search and bindings, the webdatagrid fails
Parents
No Data
Reply Children
No Data
