I added WebSchedule and all required forms to my Asp.net project. Database is Sql Server. All working ok so far. In our app user can book resources for certain customers. Now I want to add some extra fields related to appointment. For example when user makes an appointment, he/she should be able to select a customer. And calendar views should be able to filter appointments not only by resource, but customer too ("View all bookings for Room A, Customer Xyz").
How can I achieve this? How to modify AppointmentAdd.ascx and AppointmentAdd.aspx code to read and write some extra fields? Do you have any samples related to that?
We use infragistics version 2011.1
Hi jukkat,
It has been some time since your post, however in case you still need assistance I would be glad to help.
Some guidelines for customizing the WebSchedule's add appointment user control can be found at:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/html/WebSchedule_Guidelines_for_Customizing_the_Appointments_and_Reminders_Forms.html
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://www.infragistics.com/support
Hello Petar,
I added WebSchedule and all required forms to my Asp.net project. Database is Sql Server. All working ok so far. In our app we allow user to select a type. Now I want to add some extra field related to appointment. For example when user makes an appointment, he/she should be able to select a type.
I have seen the link you posted, it would be nice if you can provide some example.
Its urgent and please let me know.
