1465
Add multiple images client-side
Hello.
I looked at your example where you added one image to a WebImageViewer on the client.
I need to add several.
My code, below, will try to add three items, but only one actually gets added.
Variable "iv" is the WebImageViewer control.
I'm using IG 11.2 Ultimate.
Please advise.
Thank you,
Mike
var items = iv.get_items();
for (i = 0; i < result.length; i++) {
var item = items.createItem();
item.set_imageUrl(
"~/snapshot.aspx?uiid=" + result[i].UIID);
item.set_altText(result[i]._Description);
item.set_tooltip(result[i]._Description);
item.set_key(result[i]._MACAddress);
items.add(item);
  • 8160
    Hi Mike,
    this looks like a development issue. I will test this and will let you know what is the result.
    Thank you for your patience
  • 8160
    Hello Mike,
    use addRange function
    http://community.infragistics.com/forums/p/19444/70269.aspx
                var newItems = new Array();
                for (var i = 0; i < result.length; i++) {
    item.set_imageUrl("~/snapshot.aspx?uiid=" + result[i].UIID);
                    newItems[i] = item; //add(item);
                items.addRange(newItems);
