130
BoundCheckBoxField in WebHierarchicalDataGrid imageUrl NullReferenceException
I attempted to use a BoundCheckBoxField in the WebHierarchicalDataGrid instead of a BoundDataField and ended up with this error.  I even set the 3 image url paths on the checkbox and still receive the same error.
This is using Infragistics 2011.2 with VS 2010.
Anyone know what causes this?
[NullReferenceException: Object reference not set to an instance of an object.]
   Infragistics.Web.UI.Framework.AppStyling.StyleBot.ImageDirectoryResolved() +17
   Infragistics.Web.UI.Framework.AppStyling.StyleBot.ResolveImageUrl(String imageUrl, Boolean useCache) +316
   Infragistics.Web.UI.GridControls.BoundCheckBoxField.SaveClientProperties() +94
   Infragistics.Web.UI.Framework.ObjectBase.WriteClientCollections(StringBuilder builder, ArrayList collections) +559
   Infragistics.Web.UI.Framework.ObjectBase.SaveCollectionsStateToViewState() +196
   Infragistics.Web.UI.Framework.RunBot.HandleSaveViewState() +64
   Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.SaveViewState() +101
   Infragistics.Web.UI.GridControls.BaseGrid.SaveViewState() +189
   Infragistics.Web.UI.GridControls.WebDataGrid.SaveViewState() +50
   Infragistics.Web.UI.GridControls.ContainerGrid.SaveViewState() +245
   Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid.SaveViewState() +326
   System.Web.UI.Control.SaveViewStateRecursive(ViewStateMode inheritedMode) +147
   System.Web.UI.Control.SaveViewStateRecursive(ViewStateMode inheritedMode) +276
   System.Web.UI.Page.SaveAllState() +738
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4771
