Hi All,
I am using Infragistics webdatagrid on my Asp.Net page inside update panels. My problem is as follows:
1) I load my page in IE 8.0 the page at the initial start has low memory consumption.
2) I start doing operations like saving the record, editing the record, refreshing the record using the infragistics tool, Now my memory consumption is very high, it even does not come down.
3) The more i do the operations the more is the memory consumption, which results in the slow performance of the page.
How can i bring down the memory consumption to a minimum. I have heard of memory leaks in IE 8.0, for that i tested the page with the sIEve tool, i checked for memory leaks which were almost nill.
Please suggest me a solution for this query ASAP.
Any help would be appreciated.
Thanks in advance.
Hi kandbal,
I have tested this scenario with a WebDataGrid v. 11.2.20121.1005 (all behaviors enabled) both in and out of an UpdatePanel and am so far unable to observe any issues in IE8 (under Win7 OS). Please provide me with some details regarding your product version so that I can examine this further. A small isolated sample illustrating the issue would be greatly appreciated. I could suggest that you try placing the grid outside the update panel or alternatively disabling the grid's AJAX to check whether that makes a difference.
Please feel free to contact me if you have any additional questions.
Please do not hesitate to contact me if you are still experiencing any issues.
