Software: IE9, ASP.NET 4.0, Infragistics UltraWebGrid 11.1
Scenario: Page uses hierarchical UltraWebGrid (Infragistics) with AJAX (LoadOnDemand = Xml)
Feature-1: One column is for checkboxes along with a header checkbox - on click of header checkbox, should do automatic check/uncheck of row level checkboxes (done through JS).
Feature-2: New editable rows can be added / deleted along with zero or more non-editable rows fetched from DB (done using OnUpdateRow event and temparory dataset in session for unsaved data).
Case-1:
If OnUpdateRow is handled (server-side), then Feature-2 works, but Feature-1 does not work.
Case-2:
If OnUpdateRow is NOT handled, then Feature-1 works, but Feature-2 does not work.
Information (from Infragistics):
1. Documentation of OnUpdateRow event:
Public Event UpdateRow
Occurs when a rows' cell values are updated. Called by OnUpdateRow.
In a grid that is not using Xml LoadOnDemand, the web application developer may wish to use the UpdateRowBatch event instead of UpdateRow, for batch update processing.
If this event is handled on the server, then it will cause a PostBack to occur every time a row is edited on the client.
Note that if LoadOnDemand is set to Xml, UpdateRow is raised out-of-band.
If UpdateRow is handled on the server, all intermediate events (UpdateCell and AddRow) are postponed until the event has been raised and handled.
2. Related Links:
http://blogs.infragistics.com/forums/t/38711.aspx - tried, but does not work
http://blogs.infragistics.com/forums/p/20286/73231.aspx - one post says its a problem in grid itself
Right now I am not having enough time to prepare a sample code for this, but if any of you have encountered this before and resolved it somehow let me know
Hi Vikram_S04,
This behavior is probably caused by the specific implementation of the functions responsible for check/uncheck the checkboxes and updating the grid. So I would need your sample code or a small project, reproducing the issue in order to be able to investigate this further. Thank you.
If you still need assistance with the matter, please do not hesitate to ask.
