1370
Webtab with rounded corners and drop shadow
I am using Infragistics ASP.NET controls.  Customer has inquired about putting rounded corners and drop shadows on webtab controls.
Note that I am generating the web tab controls dynamically.  So the controls are not sitting on the aspx design surface.  I should be able to set Webtab properties - but dont think I can hook up ajax or javascript to dynamic controls.
I am confused as to whether I can create a webtab with rounded corners or not.  Some forum posts seem to say that you can enable/disable rounded corners - not sure how?  Is drop shadow possible?
If it was just straight asp.net I would use ajax control toolkit to provide these.
