540
Regarding Ultrawebgrid to Webdatagrid migration
We need to migrate to WebDataGrid from Ultrawebgrid. In out project we are using the below mentioned client side events with UltraWebGrid
Kindly let me know on the equivalent client side events so that we will able to migrate the solution to AKIDO controls.
AfterXmlHttpResponseProcessed AJAXResponse
AfterRowActivateHandler
AfterCellUpdateHandler ExitedEditMode
AfterExitEditModeHandler
AfterRowUpdateHandler
AfterRowDeletedHandler
BeforeCellUpdateHandler
BeforeRowDeletedHandler
BeforeRowInsertHandler
BeforeEnterEditModeHandler EnteredEditMode
BeforeExitEditModeHandler ExitingEditMode
BeforeClipboardOperation
BeforeCellChangeHandler
BeforeRowUpdateHandler
ColumnHeaderClickHandler
CellClickHandler Click
CellChangeHandler
RowSelectorClickHandler
MouseUpHandler
XmlHTTPResponseHandler AJAXResponse
EditKeyDownHandler
KeyDownHandler
  • 22732
    There is not a one to one mapping between the API's of the two controls and a better approach is to decide what functionality you need/want and then implement that in the WebDataGrid.  In some cases it may not be necessary to handle all of the same events or their equivalent.  You can refer to the Infragistics ASP.NET Grid Feature Cheat Sheat as a starting point on how to implement the same features.  After going through that for how to topics it is recommended that you look through the Using WebDataGrid section of the ASP.NET online documentation.
    Let me know if you have any questions with this matter.
