5020
IGSlideTabView + Auto Layout = CALayerInvalidGeometry Crash
Taking this IGSlideTabView code from the dev guide:
- (void)viewDidLoad
    [super viewDidLoad];
    self.view.backgroundColor = [UIColor purpleColor];
    IGSlideTabView *slideTabView = [[IGSlideTabView alloc] init];
    slideTabView.frame = self.view.bounds;
    slideTabView.autoresizingMask = UIViewAutoresizingFlexibleHeight|UIViewAutoresizingFlexibleWidth;
    [self.view addSubview:slideTabView];
    IGSlideTabItem *slideTabItem = [IGSlideTabItem tabWithLocation:IGSlideTabLocationBottom
                                                             title:@"Getting Started"
                                                           tabView:nil
                                                       contentView:nil];
    slideTabItem.contentSize = [IGSlideTabContentSize sizeWithWidth:200 height:200];
    [slideTabView addTab:slideTabItem];
and converting to auto layout...
- (void)viewDidLoad
    slideTabView.SE_autoLayoutEnabled = YES;
    [slideTabView SE_constrainToSuperviewAxisWithInset:CGSizeMake(0, 0) priority:1000];
                                                           tabView:nil
                                                       contentView:nil];
causes crash...
'CALayerInvalidGeometry', reason: 'CALayer position contains NaN: [nan 457.5]'
*** First throw call stack:
0   CoreFoundation                      0x01a461e4 __exceptionPreprocess + 180
1   libobjc.A.dylib                     0x015938e5 objc_exception_throw + 44
2   CoreFoundation                      0x01a45fbb +[NSException raise:format:] + 139
3   QuartzCore                          0x018a3e1a _ZN2CA5Layer12set_positionERKNS_4Vec2IdEEb + 190
4   QuartzCore                          0x018a3fd9 -[CALayer setPosition:] + 68
5   QuartzCore                          0x018a46df -[CALayer setFrame:] + 799
6   UIKit                               0x002aeb4d -[UIView(Geometry) setFrame:] + 302
7   XXXXXXXXX               0x0000d432 -[IGSlideTabView updateHorizontalTabLocation:] + 761
  • 4940
    Verified Answer
    This crash comes from the fact the subview constraints aren't yet calculated in the viewDidLoad override, which results in a frame equal to CGRectZero. When using autolayout, you want to move any code that deals with frame setting (in this case, the IGSlideTabItem) to viewDidLayoutSubviews or viewDidAppear. The viewDidLayoutSubviews method is called once autolayout has finished calculating the constraints and puts the subviews in place.
    @interface ViewController ()
        IGSlideTabView *_slideTabView;
    @end
    @implementation ViewController
    - (void)viewDidLoad
        _slideTabView = [[IGSlideTabView alloc] init];
        [self.view addSubview:_slideTabView];
        _slideTabView.SE_autoLayoutEnabled = YES;
        [_slideTabView SE_constrainToSuperviewAxisWithInset:CGSizeMake(0, 0) priority:1000];
    - (void)viewDidLayoutSubviews
        [super viewDidLayoutSubviews];
                                                               tabView:nil
                                                           contentView:nil];
        [_slideTabView addTab:slideTabItem];
    @end
