320
XamDataGrid Filtering External with multiple layouts
Hi
In your sample "Custom Filtering by External UI" you show the ability to filter using an external text box. However I have an issue with multiple Field Layouts.
I have the following code which creates a "Drill Down" grid that has two levels - a "Database" level and a "Case" level where each case has one database but each database has multiple cases.
I am using your code to implement my own external filters which works well for the the top level (database) but not for the second level.
I have modified the second  level code to use FieldLayouts[1] rather than FieldLayouts[0] but nothing happens when I perform the filter.
This is my search method which is called whenever an operand or criteria value is changed:
/// <summary>
/// Performs the search
/// </summary>
private void Search()
if (_databasesLoaded == false)
return;
var databaseLevelCollection = CasesDataGrid.FieldLayouts[0].RecordFilters;
databaseLevelCollection.Clear();
//database name
if (string.IsNullOrWhiteSpace(DatabaseNameFilter.Text) == false)
var operand = GetOperand(DatabaseNameOperand.SelectedItem.ToString());
var filter = new RecordFilter
FieldName = "DatabaseName"
filter.Conditions.Add(new ComparisonCondition(operand, DatabaseNameFilter.Text));
databaseLevelCollection.Add(filter);
//get and clear the data grid filter
var filterCollection = CasesDataGrid.FieldLayouts[1].RecordFilters;
filterCollection.Clear();
//case reference
if (string.IsNullOrWhiteSpace(CaseReferenceFilter.Text) == false)
var operand = GetOperand(CaseOperand.SelectedItem.ToString());
FieldName = "Reference"
filter.Conditions.Add(new ComparisonCondition(operand, CaseReferenceFilter.Text));
filterCollection.Add(filter);
//case description
if (string.IsNullOrWhiteSpace(CaseDescriptionFilter.Text) == false)
var operand = GetOperand(CaseDescriptionOperand.SelectedItem.ToString());
FieldName = "Description"
filter.Conditions.Add(new ComparisonCondition(operand, CaseDescriptionFilter.Text));
//case status
if (CaseStatusFilter.Text != Strings.All)
var operand = GetOperand(CaseStatusOperand.SelectedItem.ToString());
FieldName = "CurrentStatus"
filter.Conditions.Add(new ComparisonCondition(operand, CaseStatusFilter.Text));
//created by
if (string.IsNullOrWhiteSpace(CaseCreatedByFilter.Text) == false)
var operand = GetOperand(CaseCreatedByOperand.SelectedItem.ToString());
FieldName = "CreatedBy"
filter.Conditions.Add(new ComparisonCondition(operand, CaseCreatedByFilter.Text));
//last modified by
if (string.IsNullOrWhiteSpace(CaseLastModifiedByFilter.Text) == false)
var operand = GetOperand(CaseLastModifiedByOperand.SelectedItem.ToString());
FieldName = "LastModfiedBy"
filter.Conditions.Add(new ComparisonCondition(operand, CaseLastModifiedByFilter.Text));
//number of samples
if (CaseNumberOfSamplesFilter.Value != null && CaseNumberOfSamplesFilter.Value > 0)
var operand = GetOperand(CaseNumberOfSamplesOperand.SelectedItem.ToString());
FieldName = "NumberOfSamples"
filter.Conditions.Add(new ComparisonCondition(operand, CaseNumberOfSamplesFilter.Text));
The code for the field declarations is:
<igDP:XamDataGrid.FieldSettings>
<igDP:FieldSettings AllowEdit="False"
AllowGroupBy="False"
AllowRecordFiltering="true"
CellClickAction="SelectRecord"
CollapseWhenEmpty="true"
ExpandableFieldRecordExpansionMode="ShowExpansionIndicatorIfSiblingsExist"
ExpandableFieldRecordHeaderDisplayMode="NeverDisplayHeader"
FilterLabelIconDropDownType="SingleSelect"
LabelClickAction="SortByOneFieldOnly"
SortComparisonType="CaseInsensitive" />
</igDP:XamDataGrid.FieldSettings>
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings AllowAddNew="False"
AllowClipboardOperations="None"
AllowDelete="False"
AllowFieldMoving="No"
AllowRecordFixing="No"
AutoGenerateFields="False"
DataRecordSizingMode="Fixed"
ExpansionIndicatorDisplayMode="CheckOnDisplay"
FieldResizingArea="LabelsOnly"
FilterClearButtonLocation="None"
FilterRecordLocation="OnTopFixed"
FilterUIType="LabelIcons"
HeaderPrefixAreaDisplayMode="None"
RecordSelectorLocation="None"
ResizingMode="Immediate"
SelectionTypeField="None"
SelectionTypeRecord="Single" />
</igDP:XamDataGrid.FieldLayoutSettings>
<!-- The actual fields -->
<igDP:XamDataGrid.FieldLayouts>
<!-- Grim Database Level - These are the database columns -->
<igDP:FieldLayout Key="GRIMDatabase">
<igDP:FieldLayout.Fields>
<igDP:Field Name="DatabaseName" Label="{x:Static languages:Strings.DatabaseFile}" AllowRecordFiltering="True">
<igDP:Field.Settings>
<igDP:FieldSettings CellMinWidth="300" />
</igDP:Field.Settings>
</igDP:Field>
<igDP:Field Name="NumberOfCases" AllowRecordFiltering="True"
HorizontalContentAlignment="Left"
Label="{x:Static languages:Strings.TotalNumberOfCases}">
<igDP:FieldSettings CellMinWidth="200" />
</igDP:Field>
<!-- This allows us to expand and drill down into cases -->
<igDP:Field Name="AvailableCases"
IsExpandable="True"
IsPrimary="True" AllowRecordFiltering="True"
IsSelected="True"
Label="AAA" />
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
<!-- Case Level - These are the case columns -->
<igDP:FieldLayout Key="AvailableCases"
ParentFieldLayoutKey="GRIMDatabase"
ParentFieldName="AvailableCases">
<igDP:TemplateField Name="IsChecked"
AllowEdit="False"
AllowResize="False"
Label=" ">
<igDP:FieldSettings Width="50" />
<igDP:TemplateField.DisplayTemplate>
<DataTemplate>
<CheckBox HorizontalAlignment="Center"
VerticalAlignment="Center"
IsChecked="{Binding Path=Value, Mode=TwoWay, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type igDP:CellValuePresenter}}}"
Style="{StaticResource NormalCheckBox}" />
</DataTemplate>
</igDP:TemplateField.DisplayTemplate>
</igDP:TemplateField>
<igDP:Field Name="Reference" AllowRecordFiltering="True"
Label="{x:Static languages:Strings.ReferenceColumnName}">
</igDP:Field>
<igDP:Field Name="Description" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.DescriptionColumnName}">
<igDP:FieldSettings CellMinWidth="120" />
</igDP:Field>
<igDP:Field Name="CurrentStatus"
AllowEdit="False" AllowRecordFiltering="True"
Converter="{StaticResource CaseStatusTranslator}"
Label="{x:Static languages:Strings.CaseStatusColumnName}">
<igDP:FieldSettings CellMinWidth="50" />
</igDP:Field>
<igDP:Field Name="CreatedBy" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.CreatedByColumnName}">
<igDP:FieldSettings CellMinWidth="160" />
</igDP:Field>
<igDP:TemplateField Name="CreatedDate" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.CreatedDateColumnName}">
<igDP:FieldSettings CellMinWidth="130" />
<DataTemplate>
<TextBlock Text="{Binding Converter={StaticResource DateKindConverter}}" />
</DataTemplate>
<igDP:TemplateField Name="LastModifiedBy" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.LastModifiedByColumnName}">
<DataTemplate>
<TextBlock Text="{Binding Converter={StaticResource OperatorDisplayConverter}}" />
</DataTemplate>
<igDP:TemplateField Name="LastModifiedDate" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.LastModifiedDateColumnName}">
<igDP:FieldSettings CellMinWidth="170" />
<DataTemplate>
</DataTemplate>
<igDP:Field Name="NumberOfSamples" AllowRecordFiltering="True"
AllowEdit="False"
Label="{x:Static languages:Strings.NumberOfSamplesInCase}">
<igDP:FieldSettings CellMinWidth="180" />
</igDP:Field>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
