I have a hierarchical XamDatgrid with GroupBy oprion enabled.
I want ot Show Summary of by Row with a Count of total row numbers but when I group some collum i do not want to show the summary.
I try to use SummaryDisplayArea but when i choose DataRecordsOnly or TopLevelOnly the Count summary is not displayed anywhere.
Only with BottomFixed the Count summary is displayed. Does it possible to do not show summary in groupBy but only in top level part of the XamDataGrid ?
I join my sample.
Thanks for your help.
SampleXamDataGridAndSummary.zip
Hello Estimbre,
Thank you for your post. This cam be achieve by setting the SummaryDisplayArea to NoneAnd GroupByDisplayArea to InGroupByRecords.
There is a sample in or SB under xamDataGrid -> Organization -> Summary Location and UI Type which shows you the different places you can place the summaries. You can refer that sample and try multiple options to place them.
Let me know if you need further assistance.
Sincerely,
Divya Jain
Hello Divya Jain,
Thanks for your answer. I have check the sample and I see its possible to do what I want. Only Show the Count result at top Level but not in GroupBy
But I'm not able to do this in my sample. I do not fin property GroupByDisplayArea. In my case i found only property
SummaryDisplayArea with all this possible value under FieldSettings with possible values : Botom, BotomFixed, DataRecordsOnly, InGroupByRecorsn, Node, Top, TopFixed, TopLevelOnly.
I do not be able to reproduce the sample Summary Location and UI Type behavior in my attached sample
