Hi!!!
I have a problem when I'm exporting a datagrid which is grouped by 2 columns. the problem is that column values appears in a diferent column in the grid and in the excel file. When I group by 2 columns, summary values(Totals), move 2 columns right. Anyone else about what is happening. It`s a problem between Infragistics and Excel or perhaps I've to check some property from my grid?
I beleive this was recently fixed. You should get the latest Hot Fix. My Infragistics Keys and Downloads - Download Anything and Everything You Own
If that doesn't help, then you should Submit an incident to Infragistics Developer Support
