Hi!
Is there a possibility to display the grid (better would be the band) vertically? I mean normally a grid is drawn upside down, each GridRow showing a DataRow.
But we need to show the information from left to right. Consequently we will have 6 "GridRows" showing multiple "GridColumns" whereby our dataset will have 6 DataColumns with multiple DataRows. This is NOT a pivot since we do not need to have summaries. We just want to change the orientation of the grids columns and rows. We also do not need to rotate each column[header] to reflect a 90Degree text.
I am quite sure it is no complex task to do that but after a while of searching I am not sure anymore the Infragistics- Grid is capable of such a displaying- method.
I would appreciate any feedback and I do allready have alternatives if absolutly required alltought I definitly try to avoid that.
Thanks in advance and best Regards,
Rudolf Woerndle
Hi Rudolf,
You might want to try CardView and see if that's what you want. If not, then you would have to build some sort of data structure what has the colmuns and rows you want.
I have tested CardView and I guess it will do the trick for us. It's at least very very near to what I need.Thanks a lot for this information!
Btw.: The tools are sometimes tricky due to their thousands of functions but they have a unique concept- and thats what I like.So thank you for your cool tool, keep goin' then I'll keep using (and paying :> )
Rudolf
