75
export to excel returns KeyNotFoundException
Hi.
I am trying to do an export to Excel from my grid and am getting the stack dump:
System.Collections.Generic.KeyNotFoundException was unhandled
HResult=-2146232969
Message=The given key was not present in the dictionary.
Source=mscorlib
StackTrace:
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at Infragistics.Win.UltraWinGrid.GridExportCache.GetDocumentBandInfo(UltraGridBand band, PlaceholderType placeHolderType)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.SetCurrentGridObjectSpan(UltraGridExporterHelper exportHelper, UltraGridBand band, UltraGridRow row, PlaceholderType placeHolderType)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.ProcessGridRowInternal(UltraGridExporterHelper exportHelper, UltraGridRow row, ProcessRowParams processRowParams)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExporterHelper.ProcessRow(UltraGridRow row, ProcessRowParams processRowParams)
at Infragistics.Win.UltraWinGrid.RowsCollection.InternalTraverseRowsHelper(IUltraGridExporter exporter)
at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.ExportHelper(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn, Boolean asynch)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, WorkbookFormat workbookFormat)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName, WorkbookFormat workbookFormat)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName)
at ComputersUnlimited.Windows.Ultra.UltraGridExcelExporter.DoExport()
My exporter is defined like this:
var exporter = new Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter();
The call that causes the error is this:
exporter.Export( Grid, FileName );
Our grid has 2 bands on it and the second band has 1 row in it.
Each row (Grid.Rows) has a single ChildBand (Grid.Rows[0].ChildBands.Count = 1) and each ChildBand also has 1 row (Grid.Rows[0].ChildBands[0].Rows.Count = 1) with no ChildBands (Grid.Rows[0].ChildBands[0].Rows[0].ChildBands.Count = null).
I know that if I hide the child band then the export works and also does not export the child band.
What I would like to know is what the message: 'KeyNotFoundException: The given key was not present in the dictionary.' means, what is it looking for specifically and what settings/properties/data might be causing this problem to occur.  Is there some information on the band that I need and am missing, since this seems to fail in GetDocumentBandInfo.
Thank you for your time and help in this matter.  Anything could be useful.
