When I create a DPI aware app with a FlowLayoutPanel that contains several auto-sizing UltraCheckEditors, it works as expected on a system with 100% font scaling. On a high DPI system (Windows 10, 175% font scaling), the UltraCheckEditors don't resize correctly. The text in the editors wraps (because it didn't size itself correctly), which results in two lines of text, with both lines clipped because they extend above and below the control area.
Got a fix?
I did discover some workarounds.
Hi Scott,
Thank you for the sample!
I submitted this issue in our internal development tracking system under 242942. It is currently assigned to our development team and to follow up with the progress about it, you can check out the support activity tab at https://www.infragistics.com/my-account/support-activity
Let me know if I may assist you further on this matter.
Attached is a sample app.
We're using 17.1.
We have made improvements regarding the UltraCheckEditor DPI awareness in 14.2 and up. Could you let me know the Infragistics` version you use? While I am investigating this issue further, could you please send me reproducible sample application? It would definitely help me narrow down what is going on faster.
Looking forward to hear from you.
