Hello, I am trying to code logic that looks for whether an UltraGridCell.Value!=Null.
The cell looks like:
But when I run the code, it is perceiving this cell as Null. Is there another cell property that could be populating this Cell?
Lauren
I have solved with the following:
Since:
ar_trade["counterparty"].ValueList.ToString ()= "HasProxyDetail"
Then
ar_trade["counterparty"].ValueList.ItemCount!=0 will tell me if the field is populated with See details....
I am glad that worked for you. My initial thought was you may have had the NullText property set on the Column. NullText works such that, if the value is null, it will display that text.
