I'm not sure which section this belongs to. I am trying to populate the ultraMonthViewSingle1 with events happening for days within the month view.
Any suggestion as to where to go and look for a working example. The different days events are being brought in from my sql files ov events.
thanks in advance
gollnick
Hi gollnick,
We have some example code that shows how you can add appointments to any schedule control here:https://www.infragistics.com/help/winforms/winschedule-create-and-display-an-appointment
You can also refer to our databinding sample here:https://www.infragistics.com/samples/windows-forms/schedule/databinding
Still confused.
This link - https://www.infragistics.com/help/winforms/winschedule-create-and-display-an-appointment does what I want BUT I DO NOT want the dialog box that pops up. I just want to put the appointment on the control.
The second link .. I could not tell where the data was bound to the control.
I have November -- I have appointments on the 8th , 12th , 20th , 26th which I return in a dataset from my sql runs.
I just want to bind this data to my control. All the rest is fluff for me. A one/two/three step process would be great.
thanks
gollnickFOR SALE
Ok.. I having it add to multiple days in my month. When I have 2 or more appointments on the same day I get a little "carrot" but when I click it nothing happens. I am assuming that when that it clicked something should open showing the other items. Plus I only have 1 line showing
This is intended behavior. When a user clicks this button, the MoreActivityIndicatorClicked event fires. You can use this event to, for example, switch to an UltraDayView so that the user can see the full list of appointments on that day.
