NumericUpDown control is added to ControlContainerTool and it works all fine.
But When I resize the NumericUpDown, it resizes like | ---<--->
With that I cannot able to align with other controls like TextBox as shown below.
*Just for info, if I resize the combobox it resizes like --<--->----|
Hello Raavi,
I have tested this is a sample and I am unable to reproduce the behavior you describe. I have some follow up questions:
What version are you using?How are you doing the resizing?How are you laying out your page?What are the editor and other controls contained in?Can you provide an isolated sample that demonstrates the behavior you are seeing?
Sincerely,Mike P.Software DeveloperInfragistics, Inc.www.infragistics.com
Thankyou and here I attach the test project to emulate the Problem.
5618.TestingUltraToolBarToolPosition.zip
Thank you for the update. I am unable to run your sample, when I try it just hangs. Is there anything missing from the project to run it other than adding the Infragistics assemblies back in?
This project does not depend on any other assemblies apart form Infragistics. Its a simple form with a ribbon and three tools added to the ribbon group.
