I would like some assistance adding a border to the drop down menu of my button.
What I would need would be a way to differentiate the button itself and the drop down button by default. You can only tell it has a separate menu in its dropdown if you hover over it.
Can this be done without drawfilters?
EDIT: I was able to use DrawFilter and specify which one using its Key property.
I managed to follow the DrawFilter guide they had up. Now my question is how do I specify which specific PopupToolDropDownButtonUIElement I want it applied to.
Right now it is being applied in the other drop down lists that I don't want.
Hello Eric,
Thank you for your post. I am glad you were able to resolve this issue using a DrawFilter. From your most recent edit to the original post, it sounds like you were able to resolve the "specific" tool to apply your filter to using the Key property. If this is not the case, please let me know and I will continue to investigate this issue further.
