I am implementing a functionality using UltraWinGrid and not able to accomplish what I want.
My Infragistics Version details are: Infragistics4, Version 14.1
Here is the diagrammatic illustration what I actually want as below:
------------- --------------------| Employee ID | Employee Name | ------------- --------------------| ........... | .................. | <- Add New Row TemplateOnTop Visible (Based on some condition) ------------- --------------------| Emp01 | Employee Name 1 | ------------- -------------------- --------------- ------------------------------ | Department ID | Department Name | --------------- ------------------------------ | ............. | ............................ | <- Add New Row TemplateOnTop Visible (Based on some condition) --------------- ------------------------------ | Dept01 | Department Name 1 | <- All rows are enabled (Based on some condition) | Dept02 | Department Name 2 | | Dept03 | Department Name 3 | --------------- ------------------------------ ------------- --------------------| Emp02 | Employee Name 2 | ------------- -------------------- --------------- ------------------------------ | Department ID | Department Name | --------------- ------------------------------ <- Add New Row TemplateOnTop Hidden (Based on some condition) | Dept04 | Department Name 4 |<- All rows are disabled (Based on some condition) | Dept05 | Department Name 5 | | Dept06 | Department Name 6 | --------------- ------------------------------ ------------- --------------------| Emp03 | Employee Name 3 | ------------- -------------------- --------------- ------------------------------ | Department ID | Department Name | --------------- ------------------------------ | ............. | ............................ | <- Add New Row TemplateOnTop Visible (Based on some condition) --------------- ------------------------------ | Dept07 | Department Name 7 | <- All rows are enabled (Based on some condition) | Dept08 | Department Name 8 | | Dept09 | Department Name 9 | --------------- ------------------------------
Based on some specific condition I am trying to disallow add new / delete in hierarchical grid's sub grid's. But when I am trying doing it on InitializeRow event of the grid using
e.Row.Band.Layout.Override.AllowAddNew = AllowAddNew.No; e.Row.Band.Layout.Override.AllowDelete = DefaultableBoolean.False;and to show/enable:
e.Row.Band.Layout.Override.AllowAddNew = AllowAddNew.TemplateOnTop; e.Row.Band.Layout.Override.AllowDelete = DefaultableBoolean.True;Whole grid's Add New Row functionality stop working. I tried Googeling but did not found anything helpful.Please let me know how can I achieve it.Thank You!
Thank you for contacting Infragistics. You can use the InitializeTemplateAddRow event to suppress the add row from appearing within certain child rows.
eg.
private void ultraGrid1_InitializeTemplateAddRow(object sender, Infragistics.Win.UltraWinGrid.InitializeTemplateAddRowEventArgs e) { // Do not allow adding to the child band based on the parent row. Just // for purposes of example, we will disallow adding on parent rows where // the first column value is an odd number. if (e.TemplateAddRow.Band.Key == "Band 1") { var parentRow = e.TemplateAddRow.ParentRow; int value = (int)parentRow.GetCellValue("Column 0"); if (value % 2 == 1) { e.TemplateAddRow.Hidden = true; // You could also disable the row, instead of hiding it, but this is // a little weird, since there's no text in the row and it's hard to // see that it's disabled. //e.TemplateAddRow.Activation = Infragistics.Win.UltraWinGrid.Activation.Disabled; } } }
Please see the sample below for more details.
WindowsFormsApplication53.zip
