After loading a layout from XML on UltraDockManager instance, is it possible to update the Automation ID property on the WindowDockingArea and DockableWindow controls?
We are using TestComplete to automate UI testing and one of the test includes loading XML layout on the UltraDockManager. Each time a different layout is loaded, the automation IDs for WindowDockingArea and DockableWindow controls change causing the test to fail. We want to keep the automation IDs constant based on DockableControlPane it hosts. How to set AutomationID property for WindowDockingArea and DockableWindow?
Aditi
Our implementation of UI Automation is solely to support Coded UI Test. It is possible that the TestComplete framework may work with the controls, but we have not tested against it and we do not support it. If you were to use our WPF XamDockManager, I do know that we expose AutomationProperties.AutomationID (example) since we have Automation Peers on the following objectshttps://www.infragistics.com/help/wpf/infragisticswpf.dockmanager~infragistics.windows.automation.peers.dockmanager_namespace
The same may apply in Windows Forms, but its uncertain.
