30
Download specific build
If I download version 17.1 of the controls (Infragistics_20171_Platform.exe) I get the dlls with version 17.1.20171.2108. Is it possible to get a different build as I'd really like to get the 17.1.20171.1008 build versions.instead?
If possible could you tell me if there were significant bug fixes  between these two builds.
Ian.
  • 28530
    Hello Ian,
    Thank you for your post!
    When you install using the Platform Installer and you select the product type that you want to install, there is a checkbox on the right-hand side under an “Updates” item that will be checked by default. One of these for Windows Forms 2017.1 will read “Service Release – Revision 2108.” If you uncheck this, the installer will install the base version, which is 17.1.20171.1008.
    Note, since you have already installed version 17.1.20171.2108, I would recommend uninstalling and then re-installing without this option checked.
