I have added "CheckBoxUIElement" to GroupByRow in UltraWinGrid by using the instructions in article http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4340
Though while loading the Grid i want to disable the state of the checkbox on UltraGridGroupByRow Header dynamically based upon the data that is binded.
in the code we can find the UltraGridGroupByRow and on setting the tag property to Checked or Unchecked makes the checkBox Check/Uncheck.
Question is How to make the UltraGridGroupByRow checkbox at runtime and Enables its state enable and Disable
Munish
Hello Munish,
Thank you for posting. I am assisting you with checkBox state on the forums here:
www.infragistics.com/.../ultragridgroupbyrow-checkbox-controls-state
Please let me know if I may be of further assistance or if this case may be closed.
Sincerely,Divya JainAssociate Software Developer
