50
Ultragrid Red Cross Coming on the UltraGrid
in Our Scenario
When a particular User is Charting data on a grid like one item is selected by the User  So we send that data to the Server and second user has also opened the same document where grid and same data is displayed.
So we are Updating the Value passed by the first user into the collection of the second User  and again reassigning the Data source for the Second User Grid and calling the method to hide the Empty rows or cells. So that value charted by first user is reflected at second user and that cell or row is disabled.
But when we are charting the Data sometimes RED X is coming on the Grid of the 2nd user and sometimes error is not captured in the Error event handler of the grid.
Index bound of range or You cannot bind the same data source again issue coming and some object reference is not set to instance message is coming
Can You Please Provide the resolution steps how this can be resolved
Please find the Code below that is being called at the 2nd User end
   _orderCollection= New List(Of ItemAdapter(Of OrderItem))
            Note.Items.ItemscacheLock.EnterReadLock()
            Try
                For Each item As Domain.Note.Item In Note.Items
                    If Not item.IsFiltered Then
                        Dim itemAdapter As ItemAdapter(Of OrderItem) = New ItemAdapter(Of OrderItem)
                        itemAdapter .Item = item
                        Me._orderCollection.Add(itemAdapter )
                    End If
                Next
            Finally
                Note.Items.ItemscacheLock.ExitReadLock()
            End Try
_OrderGrid.AddDataSource(_orderCollection)
And then we call the Method
_OrderGrid.ModifyGridRowsShown(_header.rdoShowSelectedOnly.Checked)
where below code is called
 If Me. _OrderGrid.Rows.Count > 0 Then
                Dim row As UltraGridRow = Nothing
                For Each row In grdResult.Rows
                    If Not Nothing Is row.ChildBands Then
                        ' Loop throgh each of the child bands.
                        Dim childBand As UltraGridChildBand = Nothing
                        For Each childBand In row.ChildBands
                            Dim i As Integer
                            For i = 0 To childBand.Rows.Count - 1
                                If filter Then
                                    If Not DirectCast(childBand.Rows(i).Cells(0).Value, Boolean) Then
                                        childBand.Rows(i).Hidden = True
                                    End If
                                Else
                                    childBand.Rows(i).Hidden = False
                                End If
                            Next
                        Next
                    End If
                    If Not filter Then
                        row.Hidden = False
                        row.ExpandAll()
                    End If
                Next
            End If
Please provide the solution as issue occurring is not frequent and exception is also not captured but error displayed is some time index out of Bound and After that RED X appears
Munish
