I'm using UltraDataChart and I have problem with displayed values in axis. In below image, instead of -2.34..., 7.65... I want to have more meaningful values like 0, 10, 20, ... . By changing the axis range to (-10, 110) I can partially reach what I want, but it is not always possible. How can I achieveit?
Hello Mike,I added below two lines of code to my previous Code. (I also included the test Project. So you can run it...) xAxis.CrossingAxis = yAxis; xAxis.CrossingValue = 0;But it seems that first interval label is NOT at the axis crossing. Below image shows two values of 0 and 20 as CrossingValue. As you can see in the image, crossing point changes respectively, but there is no change in displayed values. What am I doing wrong here?!
3441.ChartTest.zip
