Hi team,
I am using VB.Net programming and I want to disable child row as per condition while it initializes.
As I attached an image I am able to disable 1st child row where written "12" but not able to disable 2nd row's child row where written "213".
I have written attached code.
Note: Child row name is "FreeText" where I can do inline editing.
Thanks in advance.
Private Sub grdue_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles grdHealthIssue.InitializeRow e.Row.Cells(ROW_NAME_AvailableList).Activation = Activation.Disabled IF e.Row.ChildBands(BAND_KEY_FreeText).Rows.Count > 0 Then e.Row.ChildBands(BAND_KEY_FreeText).Rows(0).Activation = Activation.Disabled End IF End Sub
Hello Shubharn,
What you will want to do to is check to see if the row is a part of your child band, instead of trying to check to see if the parent row has any child bands, for example
If (e.Row.Band.Key == “ChildBandName”) { }
Then if you need to check a value on the parent row before disabling the child you can do:
e.Row.ParentRow
Hi Team,
I have solved the problem by moving my code from "grdue_InitializeRow" Event to "grdue_InitializeRowCollection" Event.
Thank you for your support.
