15
Showing a column when collapsing a column group
I'm using the UltraGrid.  We have have a column group "Month" with a column for each day of the month and a Total column that is the sum of the day columns.  When a user collapsed a Month group, we want to show the Total column values for cells.  Is there a way to do this?
  • 26525
    Hello Matthew,
    I recommend using an Unbound Field as the "grand" outerbound column that you wish to show as column groups are collapsed. This column's visibility can be turned off when the groups are expanded. The grid exposes several events to hook that you can use to keep track of when a group is expanded or collapsed.
    eg. BeforeGroupCollapsed, BeforeGroupExpanded, AfterGroupCollapsed, AfterGroupExpanded
    If an unbound field isn't sufficient you can also set the total column's visible index and remove it from it's current group to the right-end of the columns. Please visit the "Working with Column Positions" topic for more details.
