I had just upgraded a WinForms project to 19.1, when I discovered this, but I can't open any form in the designer if it contains an ultracombo. This is also true of the TouchEnabledEditors sample as installed with 19.1. I can also design a new form and add the UltraCombo, but if I close and (attempt to) re-open the designer the issue occurs. Everything compiles OK.
I have both VS2017 and VS2019 installed, and the same issue appears in both. I also have Version 18.2 installed and the designer is OK for both VS2017/19.
The designer reports:
at Infragistics.Win.UltraWinGrid.RowSelectorImageInfo.get_ActiveAndDataChangedImageFromResource()at Infragistics.Win.UltraWinGrid.RowSelectorImageInfo.ResetActiveAndDataChangedImage()at Infragistics.Win.UltraWinGrid.RowSelectorImageInfo.Reset()at Infragistics.Win.UltraWinGrid.UltraGridLayout.Reset()at Infragistics.Win.UltraWinGrid.UltraGridBase.System.ComponentModel.ISupportInitialize.BeginInit()
I'm not sure if this is a bug, or something in my environment (Win 10 Pro 1809).
Thanks Harry.
I have the exact same issue. I was able to get the form open by commenting out this line in the designer file -
((System.ComponentModel.ISupportInitialize)(this.cbShift)).BeginInit();
That allows me to view the form, but as soon as it's saved it removes the comment and no longer displays.
Hello Michael,
The fix of this development issue 262903 is available in the latest bi-weekly 19.1.20191.82 builds here,
http://builds.infragistics.com/products/WinForms/2019.1/Infragistics_WinForms_20191.82_SR.zip
Please upgrade the project and let me know if you need further assistance.
Sincerely,Divya JainAssociate Software Developer
The update worked a treat.
Thanks to Mike, Divya and everyone at Infragistics for such a quick turn-around on the fix.
Harry.
Hello HMcLarnon,
Thank you for the update. I am glad that it helped.
Divya Jain
