I had designed `Line Chart`, as below,
Here Y-axis is noting but milliseconds(turn around time), I want to display it like "days:hh:mm:ss" format. Is it possible to display Y- axis lables in this format? The data binding code is as below,
ultraChartTAT.Data.DataSource = dsTAT.Tables["dtTAT"]; ultraChartTAT.Data.DataBind();
Here ultraChartTAT is an UltraChart infragistic control and dsTAT is a dataset. and ChartType is LineChart.
ultraChartTAT
UltraChart
dsTAT
dataset
ChartType
LineChart.
dsTAT.Tables["dtTAT"] structure is DataTable dtTAT = new DataTable("dtTAT"); dtTAT.Columns.Add("TAT", typeof(string)); dtTAT.Columns.Add("Sample1", typeof(Int64)); dtTAT.Columns.Add("Sample2", typeof(Int64)); dtTAT.Columns.Add("Sample3", typeof(Int64)); dtTAT.Columns.Add("Sample4", typeof(Int64)); dtTAT.Columns.Add("Sample5", typeof(Int64)); dtTAT.Columns.Add("Sample6", typeof(Int64)); dtTAT.Columns.Add("Sample7", typeof(Int64)); dtTAT.Columns.Add("Sample8", typeof(Int64));
Finally this problem is resolved
DateTimeRenderer.cs
using Infragistics.UltraChart.Resources; using System; using System.Collections; using System.Data; namespace UltraGrid { public class DateTimeRenderer : IRenderLabel { readonly DataTable source; public DateTimeRenderer(DataTable dt) { source = dt; } public string ToString(Hashtable context) { double dataValue = (double)context["DATA_VALUE"]; var dt = new DateTime((long)dataValue); return dt.ToString("MM/dd/yyyy HH:mm:ss"); } } }
Form1.cs
using System; using System.Collections; using System.Data; using System.Windows.Forms; namespace UltraGrid { public partial class Form1 : Form { DataTable table = new DataTable("Statistics"); public Form1() { InitializeComponent(); // Create columns to hold sample data. var column1 = new DataColumn("Sample", typeof(string)); var column2 = new DataColumn("Line1", typeof(Int64)); var column3 = new DataColumn("Line2", typeof(Int64)); var column4 = new DataColumn("Line3", typeof(Int64)); table.Columns.AddRange(new DataColumn[] { column1, column2, column3, column4 }); var now = DateTime.Now.Ticks; var rnd = new Random(); for (int i = 1; i < 20; i++) { table.Rows.Add(new object[] { "Sample" + i.ToString(), now + rnd.Next(999, 3600000)*1000, now + rnd.Next(999, 3600000)*1000, now + rnd.Next(999, 3600000)*1000 }); } } private void LineChartStyles_Load(object sender, System.EventArgs e) { this.ultraChart1.Data.DataSource = table; ultraChart1.Axis.Y.Labels.ItemFormatString = "<MY_VALUE>"; ultraChart1.Tooltips.FormatString = "<MY_VALUE>"; var MyLabelHashTable = new Hashtable { { "MY_VALUE", new DateTimeRenderer(table) } }; this.ultraChart1.LabelHash = MyLabelHashTable; this.ultraChart1.Data.DataBind(); } } }Form1.Designer.csnamespace UltraGrid { partial class Form1 { /// <summary> /// Required designer variable. /// </summary> private System.ComponentModel.IContainer components = null; /// <summary> /// Clean up any resources being used. /// </summary> /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param> protected override void Dispose(bool disposing) { if (disposing && (components != null)) { components.Dispose(); } base.Dispose(disposing); } #region Windows Form Designer generated code private void InitializeComponent() { System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(Form1)); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement1 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement2 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement3 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement4 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement5 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement6 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.LineChartAppearance lineChartAppearance1 = new Infragistics.UltraChart.Resources.Appearance.LineChartAppearance(); Infragistics.UltraChart.Resources.Appearance.LineAppearance lineAppearance1 = new Infragistics.UltraChart.Resources.Appearance.LineAppearance() { Thickness = 3 }; Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement7 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.LineAppearance lineAppearance2 = new Infragistics.UltraChart.Resources.Appearance.LineAppearance() { Thickness = 3 }; Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement8 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.LineAppearance lineAppearance3 = new Infragistics.UltraChart.Resources.Appearance.LineAppearance() { Thickness = 3 }; Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement9 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); this.ultraChart1 = new Infragistics.Win.UltraWinChart.UltraChart(); ((System.ComponentModel.ISupportInitialize)(this.ultraChart1)).BeginInit(); this.SuspendLayout(); this.ultraChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.LineChart; // // ultraChart1 // resources.ApplyResources(this.ultraChart1, "ultraChart1"); this.ultraChart1.Axis.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(248)))), ((int)(((byte)(220))))); paintElement1.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.None; paintElement1.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(248)))), ((int)(((byte)(220))))); this.ultraChart1.Axis.PE = paintElement1; this.ultraChart1.Axis.X.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.X.Labels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.X.Labels.ItemFormatString = "<ITEM_LABEL>"; this.ultraChart1.Axis.X.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.VerticalLeftFacing; this.ultraChart1.Axis.X.Labels.SeriesLabels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.X.Labels.SeriesLabels.FormatString = ""; this.ultraChart1.Axis.X.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.X.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.VerticalLeftFacing; this.ultraChart1.Axis.X.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.X.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.X.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.X.Labels.Visible = true; this.ultraChart1.Axis.X.LineThickness = 1; this.ultraChart1.Axis.X.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.X.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.X.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.X.MajorGridLines.Visible = true; this.ultraChart1.Axis.X.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.X.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.X.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.X.MinorGridLines.Visible = false; this.ultraChart1.Axis.X.Visible = true; this.ultraChart1.Axis.X2.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.X2.Labels.HorizontalAlign = System.Drawing.StringAlignment.Far; this.ultraChart1.Axis.X2.Labels.ItemFormatString = "<ITEM_LABEL>"; this.ultraChart1.Axis.X2.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.VerticalLeftFacing; this.ultraChart1.Axis.X2.Labels.SeriesLabels.FormatString = ""; this.ultraChart1.Axis.X2.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Far; this.ultraChart1.Axis.X2.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.VerticalLeftFacing; this.ultraChart1.Axis.X2.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.X2.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.X2.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.X2.Labels.Visible = false; this.ultraChart1.Axis.X2.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.X2.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.X2.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.X2.MajorGridLines.Visible = true; this.ultraChart1.Axis.X2.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.X2.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.X2.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.X2.MinorGridLines.Visible = false; this.ultraChart1.Axis.X2.Visible = false; this.ultraChart1.Axis.Y.Extent = 110; this.ultraChart1.Axis.Y.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.Y.Labels.HorizontalAlign = System.Drawing.StringAlignment.Far; this.ultraChart1.Axis.Y.Labels.ItemFormatString = "<DATA_VALUE:00.##>"; this.ultraChart1.Axis.Y.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Y.Labels.SeriesLabels.FormatString = ""; this.ultraChart1.Axis.Y.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Far; this.ultraChart1.Axis.Y.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Y.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Y.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.Y.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Y.Labels.Visible = true; this.ultraChart1.Axis.Y.LineThickness = 1; this.ultraChart1.Axis.Y.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Y.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.Y.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Y.MajorGridLines.Visible = true; this.ultraChart1.Axis.Y.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Y.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.Y.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Y.MinorGridLines.Visible = false; this.ultraChart1.Axis.Y.TickmarkInterval = 50D; this.ultraChart1.Axis.Y.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.Smart; this.ultraChart1.Axis.Y.Visible = true; this.ultraChart1.Axis.Y2.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.Y2.Labels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Y2.Labels.ItemFormatString = "<DATA_VALUE:00.##>"; this.ultraChart1.Axis.Y2.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Y2.Labels.SeriesLabels.FormatString = ""; this.ultraChart1.Axis.Y2.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Y2.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Y2.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Y2.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.Y2.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Y2.Labels.Visible = false; this.ultraChart1.Axis.Y2.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Y2.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.Y2.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Y2.MajorGridLines.Visible = true; this.ultraChart1.Axis.Y2.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Y2.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.Y2.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Y2.MinorGridLines.Visible = false; this.ultraChart1.Axis.Y2.Visible = false; this.ultraChart1.Axis.Z.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.Z.Labels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Z.Labels.ItemFormatString = ""; this.ultraChart1.Axis.Z.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Z.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Z.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Z.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Z.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.Z.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Z.Labels.Visible = true; this.ultraChart1.Axis.Z.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Z.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.Z.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Z.MajorGridLines.Visible = true; this.ultraChart1.Axis.Z.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Z.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.Z.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Z.MinorGridLines.Visible = false; this.ultraChart1.Axis.Z.Visible = false; this.ultraChart1.Axis.Z2.Labels.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Axis.Z2.Labels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Z2.Labels.ItemFormatString = ""; this.ultraChart1.Axis.Z2.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Z2.Labels.SeriesLabels.HorizontalAlign = System.Drawing.StringAlignment.Near; this.ultraChart1.Axis.Z2.Labels.SeriesLabels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Horizontal; this.ultraChart1.Axis.Z2.Labels.SeriesLabels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Z2.Labels.SeriesLabels.Visible = true; this.ultraChart1.Axis.Z2.Labels.VerticalAlign = System.Drawing.StringAlignment.Center; this.ultraChart1.Axis.Z2.Labels.Visible = false; this.ultraChart1.Axis.Z2.MajorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Z2.MajorGridLines.Color = System.Drawing.Color.Gainsboro; this.ultraChart1.Axis.Z2.MajorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Z2.MajorGridLines.Visible = true; this.ultraChart1.Axis.Z2.MinorGridLines.AlphaLevel = ((byte)(255)); this.ultraChart1.Axis.Z2.MinorGridLines.Color = System.Drawing.Color.LightGray; this.ultraChart1.Axis.Z2.MinorGridLines.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; this.ultraChart1.Axis.Z2.MinorGridLines.Visible = false; this.ultraChart1.Axis.Z2.Visible = false; this.ultraChart1.Border.CornerRadius = 5; this.ultraChart1.ColorModel.AlphaLevel = ((byte)(150)); this.ultraChart1.ColorModel.ModelStyle = Infragistics.UltraChart.Shared.Styles.ColorModels.CustomLinear; paintElement2.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient; paintElement2.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(108)))), ((int)(((byte)(162)))), ((int)(((byte)(36))))); paintElement2.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal; paintElement2.FillStopColor = System.Drawing.Color.FromArgb(((int)(((byte)(148)))), ((int)(((byte)(244)))), ((int)(((byte)(17))))); paintElement2.Stroke = System.Drawing.Color.Transparent; paintElement3.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient; paintElement3.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(7)))), ((int)(((byte)(108)))), ((int)(((byte)(176))))); paintElement3.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal; paintElement3.FillStopColor = System.Drawing.Color.FromArgb(((int)(((byte)(53)))), ((int)(((byte)(200)))), ((int)(((byte)(255))))); paintElement3.Stroke = System.Drawing.Color.Transparent; paintElement4.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient; paintElement4.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(215)))), ((int)(((byte)(0)))), ((int)(((byte)(5))))); paintElement4.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal; paintElement4.FillStopColor = System.Drawing.Color.FromArgb(((int)(((byte)(254)))), ((int)(((byte)(117)))), ((int)(((byte)(16))))); paintElement4.Stroke = System.Drawing.Color.Transparent; paintElement5.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient; paintElement5.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(230)))), ((int)(((byte)(190)))), ((int)(((byte)(2))))); paintElement5.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal; paintElement5.FillStopColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(255)))), ((int)(((byte)(81))))); paintElement5.Stroke = System.Drawing.Color.Transparent; paintElement6.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.Gradient; paintElement6.Fill = System.Drawing.Color.FromArgb(((int)(((byte)(252)))), ((int)(((byte)(122)))), ((int)(((byte)(10))))); paintElement6.FillGradientStyle = Infragistics.UltraChart.Shared.Styles.GradientStyle.Horizontal; paintElement6.FillStopColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(208)))), ((int)(((byte)(66))))); paintElement6.Stroke = System.Drawing.Color.Transparent; this.ultraChart1.ColorModel.Skin.PEs.AddRange(new Infragistics.UltraChart.Resources.Appearance.PaintElement[] { paintElement2, paintElement3, paintElement4, paintElement5, paintElement6}); this.ultraChart1.Data.EmptyStyle.LineStyle.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dash; this.ultraChart1.Data.SwapRowsAndColumns = true; this.ultraChart1.ForeColor = System.Drawing.SystemColors.ControlText; this.ultraChart1.Legend.Font = new System.Drawing.Font("Verdana", 7F); this.ultraChart1.Legend.Location = Infragistics.UltraChart.Shared.Styles.LegendLocation.Top; this.ultraChart1.Legend.Visible = true; lineAppearance1.IconAppearance.CharacterFont = new System.Drawing.Font("Microsoft Sans Serif", 12F); paintElement7.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.None; lineAppearance1.IconAppearance.PE = paintElement7; lineAppearance1.Key = "Monday"; paintElement8.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.None; lineAppearance2.IconAppearance.PE = paintElement8; lineAppearance2.Key = "Tuesday"; lineAppearance2.LineStyle.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dash; paintElement9.ElementType = Infragistics.UltraChart.Shared.Styles.PaintElementType.None; lineAppearance3.IconAppearance.PE = paintElement9; lineAppearance3.Key = "Wednesday"; lineAppearance3.LineStyle.DrawStyle = Infragistics.UltraChart.Shared.Styles.LineDrawStyle.Dot; lineChartAppearance1.LineAppearances.Add(lineAppearance1); lineChartAppearance1.LineAppearances.Add(lineAppearance2); lineChartAppearance1.LineAppearances.Add(lineAppearance3); this.ultraChart1.LineChart = lineChartAppearance1; this.ultraChart1.Name = "ultraChart1"; this.ultraChart1.Tooltips.Font = new System.Drawing.Font("Microsoft Sans Serif", 7.8F); this.ultraChart1.Tooltips.HighlightFillColor = System.Drawing.Color.DimGray; this.ultraChart1.Tooltips.HighlightOutlineColor = System.Drawing.Color.DarkGray; // // Form1 // this.BackColor = System.Drawing.Color.White; resources.ApplyResources(this, "$this"); this.Controls.Add(this.ultraChart1); this.Name = "Form1"; this.Load += new System.EventHandler(this.LineChartStyles_Load); ((System.ComponentModel.ISupportInitialize)(this.ultraChart1)).EndInit(); this.ResumeLayout(false); } #endregion private Infragistics.Win.UltraWinChart.UltraChart ultraChart1; } }
