85
UltraPivotGrid disable sorting in columns
Hi
Is there a way to disable the alphabetical sorting of the columns?
Thanks.
  • 5635
    Hello Zigor,
    Thank you for posting.In Pivot grid showing the columns in alphabetical order is the default behavior of the grid , In UltraPivotGrid we do not expose any property to handle this behavior, instead if you can use XamPivotGrid then we do expose ‘PreserveMembersOrder’ to handle columns order, You can try that.
    For UltraPivotGrid having this property or changing the columns order would be a new feature idea.
    You can suggest new product ideas for future versions (or vote for existing ones) at <ideas.infragistics.com>.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea
    Sincerely,
    Divya Jain
    Associate Software Developer
