30
New joiner on Ultratree
Hi I'm new on Infragistics Tools .
I wanted to build an ultratree based on an SQL view. The data is Added as BindingSource per code.
Result is given me the needed data on right structure (parent / child)
I don't find the way how
- the check box from the (SynchronizedCheckBox) should be bound to a value in dataset column 1
- column 2 should be invisible , also all columns after column 4
- column 3 is my text
- column 4 should be an input box / textbox where i can add - modify data
Or should i better go to Grid ?
Thanks for all help
  • 30
    the visible/invisibe I found out with
    Ultrawintree.ColumnSettings.ColumnSets(0).Columns("Checkbox").Visible = False
    Ultrawintree.ColumnSettings.ColumnSets(1).Columns("Checkbox").Visible = False
    but I Don't know what is 0 and 1 meaning, in my tests 0 switch off on very first level and the 1 switch off on all other sublevels
    Also when I add
     UltraWinTree.ViewStyle = UltraWinTree.ViewStyle.Standard
     UltraWinTree.Override.NodeStyle = NodeStyle.SynchronizedCheckBox
    I get the synchronised check box, and only the first column of my dataset which should be hidden , it's here the value of "Checkbox"
    By removing the 2 lines I have the tree as I want except the missing check box and the free input box.
    May be someone can tell me how to add an additional column (checkbox style) in first place which I can fill by code on line generation. Should be checked if the data in ID-code is not NULL.
  • 5635
    Hello ,
    Thank you for posting .About your first question ,SynchronizedCheckboxes only works on the nodes whose style is CheckBox. So you can't really do that with multiple columns. It might be a nice feature for us to allow them to link it to a column.
    You can suggest new feature idea for future versions (or vote for existing ones) at <ideas.infragistics.com>.
    Regarding to hide the columns you can use Visible property. and the best place to do that is in the ColumnSetGenerated event. Something like this :
    rootColumnSet.Columns["CustomerID"].Visible = false;
    For having a textbox column having editing capabilities you can get it by setting the UltraTree.Override.LabelEdit property to true. This will cause a TextBox to appear in the node when the user tries to edit the node.
    You can also refer to this post discussing the same behavior:https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/49388/how-to-add-textboxes-to-ultratree-nodes
    Let me know if you have any question.
    -Divya Jain
