30
Ultrawingrid problems to filter and collapse
Dear all
I tried the UltrawinGrid and wanted to
- if checkbox1 in screen is checked i want to see all data , if not then I want only data which have in column called "A" value TRUE
I coded Following
Private Sub ugConsentement_FilterRow(sender As Object, e As FilterRowEventArgs) Handles ugConsentement.FilterRow
If CheckBox1.Checked = False Then
e.RowFilteredOut = Not e.Row.Cells("A").Value
Else
e.RowFilteredOut = False
End If
End Sub
This works but only for all rows higher the BAND 0. So I triedto add a change on datasource with code :
If _DataSourceCS_Consentement_Grid Is Nothing Then Return
If CheckBox1.Checked Then
_DataSourceCS_Consentement_Grid.rowFilter("A=True")
Else
_DataSourceCS_Consentement_Grid.rowFilter("")
End If
this works for Band 0 . I think there will be an other simpliest solution  ?
With the combination of these 2 the
.Rows.CollapseAll(True)
looks like keeping the  Grid.rowFilter("A=True") as active  … Strange
As I'm on multiband is there also a way to detect the [+] symbol in front of each row so that he is only shown when really there are childs below.
Thanks for your help and have a nice day.
