75
UltraCombo ignores case when selecting values with keyboard
When a value occurs twice in a dropdown, but with different casing, it is impossible to select the second one by typing the value. The UltraCombo will always select the first one - regardless of the case.
Here's an example (Windows Forms, C#, .NET 4.x):
public class Form1 : Form
	public Form1()
	    InitializeComponent();
	    ultraCombo.DataSource = GetDataTable();
	private static DataTable GetDataTable()
	    var dataTable = new DataTable();
	    dataTable.Columns.Add("Code", typeof(string));
	    dataTable.Columns.Add("Description", typeof(string));
	    dataTable.Rows.Add("a", "lowercase"); // Selectable with a or A
	    dataTable.Rows.Add("B", "UPPERCASE"); // Selectable with b or B
	    dataTable.Rows.Add("c", "lowercase"); // Selectable with c... or C
	    dataTable.Rows.Add("C", "UPPERCASE"); // Cannot select with keyboard
	    return dataTable;
	private void UltraCombo_RowSelected(object sender, Infragistics.Win.UltraWinGrid.RowSelectedEventArgs e)
	    selectedLabel.Text = e.Row != null ? $@"{e.Row.Cells["Code"].Value} {e.Row.Cells["Description"].Value}" : null;
	private void InitializeComponent()
	    this.ultraCombo = new Infragistics.Win.UltraWinGrid.UltraCombo();
	    this.selectedLabel = new System.Windows.Forms.Label();
	    ((System.ComponentModel.ISupportInitialize)(this.ultraCombo)).BeginInit();
	    this.SuspendLayout();
	    // ultraCombo
	    this.ultraCombo.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.None;
	    this.ultraCombo.CharacterCasing = System.Windows.Forms.CharacterCasing.Normal;
	    this.ultraCombo.Location = new System.Drawing.Point(8, 8);
	    this.ultraCombo.Name = "ultraCombo";
	    this.ultraCombo.RowSelected += new Infragistics.Win.UltraWinGrid.RowSelectedEventHandler(this.UltraCombo_RowSelected);
	    // selectedLabel
	    this.selectedLabel.Location = new System.Drawing.Point(8, 40);
	    this.selectedLabel.Name = "selectedLabel";
	    // Form1
	    this.Controls.Add(this.ultraCombo);
	    this.Controls.Add(this.selectedLabel);
	    this.Name = "Form1";
	    this.Text = "UltraCombo";
	    ((System.ComponentModel.ISupportInitialize)(this.ultraCombo)).EndInit();
	    this.ResumeLayout(false);
	    this.PerformLayout();
private Infragistics.Win.UltraWinGrid.UltraCombo ultraCombo;
private System.Windows.Forms.Label selectedLabel;
Typing "a" selects the first item
Typing "A" (shift + a) selects the first item
Typing "b" selects the second item
Typing "B" (shift + b) selects the second item
Typing "c" selects the third item
Typing "C" (shift + c) selects... the third item whereas I expected the fourth
Changing the order in which c and C get added to the datatable, switches behavior. In that case it's always uppercase C that gets selected regardless typing "c" or "C"
The a-A and b-B cases are understandable and probably convenient for the user. The c-C case is wrong in my opinion. The UltraCombo should only try to select the first best match if no exact match was found. Especially because AutoCompleteMode is set to None.
My question: Is there a way to make the UltraCombo properly case-sensitive? It's okay if the a-A and b-B cases become case-sensitive too.
I found a topic that discusses exactly the same problem:
UltraCombo is ignoring case when selecting values (6 years ago)
Sadly the posted solution does not work for me. AutoCompleteMode is already None, CharacterCasing is Normal and adding "dataTable.CaseSensitive = true" to the example above makes no change.
