I am just starting to use the Infragistics controls. I am identifying the advantages to each control. The first thing I did was drag an UltraLabel to the form and change to my existing style which was calibri 11pt. I compared to the standard VS IDE label and the appearance was different. I spent 30 minutes trying to match the IDE font because it looks better with more body to it. Thanks for the input.
Stan
By default we use GDI+ to render the text. This property will affect how the text renders when settings like ClearType are enabled. If you set the TextRenderingMode property on the label to GDI it will render the same as a MS label.
YES! That is what I was missing. Thank you for the quick response. Have a great day.
Stanomatic
