15
Restrict to select only sundays using UltraDateTimeEditor
How can user select only Sundays using  UltraDateTimeEditor. other than Sundays ,all of the days should be disable.
  • 300
    UltraDateTimeEditor provides the ability to restrict a range of dates that will be accepted by the control only. If you would like to use an extended array of functionalities, I'd recommend using our UltraCalendarCombo (Infragistics.Win.UltraWinSchedule) component instead.
    Adding UltraCalendarCombo, allows the addition of the following controls as well:
    UltraCalednarInfo
    UltraCalendarLook
    UltraCalendarInfo allows the restriction of dates by day of the week. Restricting all days but Sundays would look as follows:
    foreach(var day in this.ultraCalendarInfo1.DaysOfWeek)
                    if (day.LongDescriptionResolved.ToString() == "Sunday") day.Enabled = true;
                    else day.Enabled = false;
    Should you have any further questions or concerns, please let me know.
    Sincerely,
    Tihomir Tonev
    Associate Software Developer
