215
UltraCombo column , how to undo
Hi
I have an ultracombo column on a grid. When I do the grids PerformAction(UltraGridAction.UndoCell) it does not set the combo item back to it's original value. Although, the value of the cell is set back to its original value when I look in code. For example:
I have a drop down with value like so
Value Member : Display Member
1                    :   One
2                    :   Two
say the value in the cell is currently 1 so the display reads One, I then choose Two but I have code to cancel that and also PerformAction(UndoCell) , what happens then is the cell shows value 1 but text 2 i.e:
1                   :   Two
How do I undo it properly?
Paul
