Using Infragistics2.Win.UltraWinChart.v12.1, Version 12.1.20121.1001 in C# .NET 4.6.1.
I've set up a simple polar chart with a datasource of type System.Windows.Data.DataTable. The DataTable has 2 columns, with column 0 holding the angular values and column 1 holding the radial distance values. When using TickmarkStyle.Smart and RangeType.Automatic on my Y axis (the one associated with radial distance values), the grid lines appear to be drawn randomly at times, whereas typically they are drawn adjacent to a tickmark label. See screenshots below:
Expected Behavior:
Notice how the data displayed in the table on the right suggests that the axis labels and major grid lines are in-sync (i.e. at 120 degrees, the radial value is 354, and the point is displayed very close to the major axis line labeled 350).
Strange Behavior:
Notice that the labels appear nowhere near the major grid lines shown. Also, looking at the data on the right, notice that at 100 degrees the radial value is 57, and at 110 degrees the value is 47, indicating that the major grid line has been drawn somewhere between 45 and 55.
What could be causing this behavior? See my attached code:
PolarChartExampleUI.zip
Thanks.
Hello Tom,
Thank you for contacting.
I would like to inform you that version 12.1 is no longer supported.
You are using CLR 4.6 , as per the support environment page CLR 4.6 would be supported for version 15.1 and later.
https://www.infragistics.com/support/supported-environments
Although I am able to setup the application using you’re the files you provided and I will compare if the behavior is same against supported version V21.1 or you are missing any property.
I’ll keep you posted with my progress by tomorrow EOD
So I run the sample against 12.1.20121.1001 and able to reproduce the behavior you described, but I am not able to reproduce the behavior using latest supported version 20.2/21.1(attached the screenshot for the reference)
So possible we had some issue long back which is fixed later in some version.
So in order to have this issue resolved you would have to get the latest assemblies/dlls if you have license for that.
Let me know if you have any question.
You can download the latest SR of 12.1 using the link below also included the fix:
http://download.infragistics.com/products/NetAdvantage/WindowsForms/2012.1/SR/NetAdvantage_WinForms_20121.2135_SR.zip
Thanks for the quick help!
