I'm using and Infragistics.Win.UltraWinGrid.UltraCombo binder to an ultradataset in order to make a multilselect dropdown for several items (82 items). The multiselect is behaving as expected except for the last item on the list. If I check the last item on the list, the text part of the ultracombo never shows the description of the last item. Any work around this??
Hello Luis,
I have put together a sample project to try to test the behavior you are seeing, but upon selecting the last value in the UltraCombo, I am able to see the related value in the text part of the combo, and so I cannot seem to reproduce the behavior you are seeing.
I am attaching the sample project I used to test this. If this sample does not match the behavior you are seeing, can you please modify it and send it back such that it does? Alternatively, if you have a sample that demonstrates the behavior you are seeing, can you please attach it?
UltraComboLastItemSelectionTest.zip
Thank you Andrew for your fast response.
Please see attached for the sample code that you provided, modified to simulate my issue.
3302.UltraComboLastItemSelectionTest.zip
Thank you for the sample project. I have been picking it apart and I have found that strangely, the property that is causing this issue appears to be the UseFlatMode property being set to true. If this is set to false, the issue no longer happens.
This appears to be a bug in the control, and I have asked our engineering teams to examine it further. To ensure it receives attention, I have logged this behavior in our internal tracking systems with a development ID of 274919. I have also created a private support case for you that I will be linking this issue to so that you can be notified when a fix or other resolution becomes available. This case has an ID of C-00227733 and you can access it after signing into your account on the Infragistics website, here: https://account.infragistics.com/support-cases.
You can continue to send updates to this thread or the support case at any time.
