I am trying to add a separator in between columns during the initialize layout event execution. I previously had the code after the Initalize layout was fired, but I wanted to move it bec I saw it have a performance hit which I am trying to improve. When I move it to the Initialize Layout the separator just gets added at the end of the grid and not in between the columns that I set it to. Can you please tell me why this doesnt work and where can I apply the code to add a seprartor to be in between columns. Is there a different event I can use or a property I can set to speed up rendering? Thaks
Hello Arnold,
You have one duplicate post this :https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/125090/winforms-ultragrid-performance-of-adding-a-seprator-to-grid?focus=true
We can discussing the behavior with this post.
So about performance issue ,did you try using load event ?
About column separator , i dont think we have any inbuild feature for that , we do have column pinning and all ,so can you provide the code /sample of your scenario, i will try to reproduce the behavior at our end.
Looking forward to hear you back.
