Hey All:
I'm working with a UltraWinGrid from the 2007 release (7.1), and have run into a problem that has left me scratching my head for the last few hours...
What we're trying to do is select multiple rows in a grid, and show those rows highlighted in one specific color. I've set the ActiveRow appearance to be slightly different (the darker blue that you'll see in the screenshot below), and the selected rows to be another color. The problem I'm having is that after clicking on a new row to add it to the selection, the ActiveRow appearance works fine, but only the cell that was clicked previously is highlighted with the SelectedRow BackColor property. The BackColor2 property also seems to have no effect. The only thing that will make the row appear as intended is turning on the Row Selectors, which we want to avoid if at all possible.
Is there a setting somewhere that I'm missing that will allow the full row to be highlighted after adding other rows to the selection?
Here's what it looks like in the designer when I add another row to the selection, for reference:
Do you have the latest Hot Fix? This looks like a bug that existed in the release build of v7.1 but was fixed in the first hot fix.
No dice. I'm still seeing the same behavior.
Hi James,
You don't have the right setup, it works fine for me. Make sure you have DisplayLayout.CellClickAction property set to RowSelect.
*dingdingdingdingding!*
That's exactly what I was looking for. I can't believe I overlooked that for this long...
Thanks a ton. :)
