Hello!
I'm converting winform combo boxes to the Infragistic's counterpart. Some of these boxes are databound through a binding source and the issue I'm having is that with the windows components I have been able to set SelectedItem to the underlying dataobject to select the Item I want to in the combo. The infragistics components will only accept an ValueListItem for SelectedItem. Is there any straightforward, "pretty" way to select an specific item in the combo box when only using the dataobject?
Regards, Johan
Hi Johan,
You could get the value of the dataobject and set the Value property of the combo.
