I need to remove the name of the band in the ColumnChooserControl.
I'm using a datasouce with multiple arrays and the grid is multiband. But only one band is shown.
When I use a simple datasource and singleband the ColumnChooserControl don't show the band...
tks,
Ricardo Amorim
Ricardo,
You could try setting the MultipleBandSupport property of the column chooser to SingleBandOnly to see if that will still show your columns without the band name.
-Matt
Matt,
I already tryed setting the MultipleBandSupport to SingleBandOnly but the ColumnChooserControl still show the band name. This works only If I use a datasource with no arrays inside.
Ricardo
Hi Ricardo,
I don't see any way to turn off the band name, then. I would think that MultiBandSupport would do it. That might be a bug. You should Submit an incident to Infragistics Developer Support so they can check it out.
