I have 2 questions
1. Exists (or not) some report designing GUI tool ? If exists Where I can get it?
2. Where I can find report (save/load) xml schema
Thanks.
PS: My Infragistics NetAdvantage software version is 2008 v.2
1) There is currently no GUI for designing a report. You should submit a feature request through Developer Support.
2) There is a sample for the Documents assembly that loads an XML file. All samples for the Documents assembly are within the same project, which is available as part of the NetAdvantage SDK. The relevant block within this code sample is surrounded by a "LoadXML" region. You can save an xml file using the Save method.
-Matt
There is no standalone XML schema, no. That loading and saving sample simple allows you to save or load the contents of a previously-created report, with the option of replacing certain areas (see the Callback sample). As I mentioned, you can submit a feature request for the designer.
Ok. Thanks
