60
How to generate a PDF file from a text file using Infragistics.Documents.PDF.PdfDocument
Is it possible to create/generate a PDF file from an existing text file using Infragistics.Documents.PDF.PdfDocument? If not, how do you use the 'PdfDocument' class to create a new PDF file? I am able to add a page and generate a PDF file, but don't know how to write text to it? I am using VB.NET 2008
 Dim PDF As New Infragistics.Documents.PDF.PdfDocument
With PDF
  .AddPage()
  .Generate("C:\Test.pdf")
End With
