40
Loading application style failes running Click-Once Deployment application
 I am using the AppStylist in a Windows Forms application. The style I am using is stored in a subdirectory, and at program start I am using this code to access the style:
                Application.EnableVisualStyles();
                Application.SetCompatibleTextRenderingDefault(false);
                Infragistics.Win.AppStyling.StyleManager.Load("Styles/Office2007Blue_Modified.isl");
The "Copy to output directory" attribute of the file is set to "Copy if newer" and running this code to initialize the styles has never been a problem.
Now that I publish my application using the "Publish" feature of the Windows Forms project (with feature "always run from shared path") and publish the application to a shared drive (or local drive for that matter) and run the application, it seems that the application can not find the style file and I get the exception:
Could not find a part of the path: "c:\documents and settings\myusername\Local Settings\Apps\2.0\97NE5X9H.DNB\K0DC3B00\vord..tion_{some cryptic hex coded string}\Styles\Office2007Blue_modified.isl".
Is there a way to fix this?
Markus
