Following error appears when I try to drop down :System.FormatException: La chaîne n'a pas été reconnue en tant que DateTime valide.
I'm using a french environnement (windows vista, visual studio 2008).
English message should be :System.FormatException: String was not recognized as a valid DateTime.
To reproduce the error, Just start a new project, insert a Ultradatetime editor control, execute the project, try to dropdown and CRASH.
Any idea ?
I was not able to reproduce the issue you described here using the French (France) culture settings. Sometimes exceptions which we safely catch are thrown by the control, which could cause this behavior if you set your debugger to throw all exceptions. If you have checked the 'Thrown' column on the Debug->Exceptions->Common Language Runtime Exceptions settings, that might explain this. If you have ruled this out you should report this as a bug.
The same result in italian
************** Testo dell'eccezione **************System.FormatException: Stringa non riconosciuta come valore DateTime valido. in System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles) in System.Convert.ToDateTime(String value, IFormatProvider provider) in Infragistics.Win.UltraWinMaskedEdit.EditInfo.MaxValueForMask(Object maxValue, String mask) in Infragistics.Win.UltraWinMaskedEdit.EditInfo.CalculateTrueMaxValue() in Infragistics.Win.MonthDropDown.DoDropDown(EmbeddableUIElementBase element) in Infragistics.Win.DateTimeEditor.DoDropDown() in Infragistics.Win.EmbeddableEditorBase.DropDown() in Infragistics.Win.DateTimeEditorDropDownButtonUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) in Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e) in Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e) in Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) in Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e) in System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) in System.Windows.Forms.Control.WndProc(Message& m) in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************mscorlib Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3082 (QFE.050727-3000) Base di codice: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities Versione assembly: 9.0.0.0 Versione Win32: 9.0.21022.8 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll----------------------------------------System.Windows.Forms Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities.Sync Versione assembly: 9.0.0.0 Versione Win32: 9.0.21022.8 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll----------------------------------------Microsoft.VisualStudio.Debugger.Runtime Versione assembly: 9.0.0.0 Versione Win32: 9.0.21022.8 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll----------------------------------------vshost Versione assembly: 9.0.0.0 Versione Win32: 9.0.21022.8 Base di codice: file:///C:/Documents%20and%20Settings/pBrescianini/Documenti/Visual%20Studio%202008/Projects/GCMARK/ImportaXLS/DataTest/DataTest/bin/Debug/DataTest.vshost.exe----------------------------------------mscorlib.resources Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3082 (QFE.050727-3000) Base di codice: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Infragistics2.Shared.v9.1 Versione assembly: 9.1.20091.1000 Versione Win32: 9.1.20091.1000 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Shared.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v9.1 Versione assembly: 9.1.20091.1000 Versione Win32: 9.1.20091.1000 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v9.1.dll----------------------------------------Infragistics2.Win.v9.1 Versione assembly: 9.1.20091.1000 Versione Win32: 9.1.20091.1000 Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v9.1.dll----------------------------------------Microsoft.VisualBasic Versione assembly: 8.0.0.0 Versione Win32: 8.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System.Data Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Deployment Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll----------------------------------------System.Design Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------System.Xml Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3082 (QFE.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------DataTest Versione assembly: 1.0.0.0 Versione Win32: 1.0.0.0 Base di codice: file:///C:/Documents%20and%20Settings/pBrescianini/Documenti/Visual%20Studio%202008/Projects/GCMARK/ImportaXLS/DataTest/DataTest/bin/Debug/DataTest.EXE----------------------------------------System.Windows.Forms.resources Versione assembly: 2.0.0.0 Versione Win32: 2.0.50727.3053 (netfxsp.050727-3000) Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll----------------------------------------
Same in English and the WinGrid is bound to a DateTime column of a DataTable and data is valid.
Is there a workaround or fix available?
************** Exception Text **************System.FormatException: String was not recognized as a valid DateTime. at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles) at System.Convert.ToDateTime(String value, IFormatProvider provider) at Infragistics.Win.UltraWinMaskedEdit.EditInfo.MaxValueForMask(Object maxValue, String mask) at Infragistics.Win.UltraWinMaskedEdit.EditInfo.CalculateTrueMaxValue() at Infragistics.Win.MonthDropDown.DoDropDown(EmbeddableUIElementBase element) at Infragistics.Win.DateTimeEditor.DoDropDown() at Infragistics.Win.EmbeddableEditorBase.DropDown() at Infragistics.Win.DateTimeEditorDropDownButtonUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3074 (QFE.050727-3000) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities Assembly Version: 9.0.0.0 Win32 Version: 9.0.30729.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities.Sync Assembly Version: 9.0.0.0 Win32 Version: 9.0.30729.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll----------------------------------------Microsoft.VisualStudio.Debugger.Runtime Assembly Version: 9.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll----------------------------------------vshost Assembly Version: 9.0.0.0 Win32 Version: 9.0.30729.1 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/spServerManager.vshost.exe----------------------------------------Infragistics2.Win.UltraWinDataSource.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDataSource.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDataSource.v9.1.dll----------------------------------------System.Configuration.Install Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------System.DirectoryServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.DirectoryServices/2.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll----------------------------------------System.DirectoryServices.Protocols Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.DirectoryServices.Protocols/2.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.Protocols.dll----------------------------------------System.Runtime.Serialization.Formatters.Soap Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll----------------------------------------System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll----------------------------------------System.ServiceProcess Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3074 (QFE.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3074 (QFE.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------Infragistics2.Win.UltraWinExplorerBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinListView.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListView.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListView.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinToolbars.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v9.1.dll----------------------------------------Infragistics2.Shared.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Shared.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Shared.v9.1.dll----------------------------------------Infragistics2.Win.Misc.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.Misc.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinListBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinStatusBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinTabbedMdi.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabbedMdi.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabbedMdi.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinTabControl.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v9.1.dll----------------------------------------Infragistics2.Win.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v9.1.dll----------------------------------------spServerManager Assembly Version: 1.2.0.28925 Win32 Version: 1.2.0.0 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/spServerManager.EXE----------------------------------------SalesPage.Shared.Common Assembly Version: 1.1.0.28693 Win32 Version: 1.1.0.0 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/SalesPage.Shared.Common.DLL----------------------------------------SalesPage.Shared.WinForms.Controls.PropertyGrid Assembly Version: 2.2.3.54 Win32 Version: 2.2.3.54 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/SalesPage.Shared.WinForms.Controls.PropertyGrid.DLL----------------------------------------SalesPage.Shared.Logging Assembly Version: 1.2.10.35565 Win32 Version: 1.2.10 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/SalesPage.Shared.Logging.DLL----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------Infragistics.License Assembly Version: 1.0.5005.10 Win32 Version: 1.0.5005.10 CodeBase: file:///C:/Windows/assembly/GAC/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------SalesPage.Exchange.Configuration Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/SalesPage.Exchange.Configuration.DLL----------------------------------------VDialog Assembly Version: 1.5.3383.35566 Win32 Version: 1.5.3383.35566 CodeBase: file:///C:/DevFiles/SalesPage.Exchange/SalesPage.Exchange.Configuration.Console/bin/Debug/VDialog.DLL----------------------------------------13zgl3hy Assembly Version: 1.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------
I beleive this is a known bug and I have forwarded this thread to the Infragistics Devloper Support team so that you can be added to the notification list and notified when a fix becomes available.
Same problem in german version.
Value property of the UltraDateTimeEditor was set to an DateTime Object. Display and direct edit ist Working.
As soon as i press the pulldown button to open the calendar popup displays the following runtime message:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.FormatException: String was not recognized as a valid DateTime. at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles) at System.DateTime.Parse(String s, IFormatProvider provider) at System.Convert.ToDateTime(String value, IFormatProvider provider) at Infragistics.Win.UltraWinMaskedEdit.EditInfo.MaxValueForMask(Object maxValue, String mask) at Infragistics.Win.UltraWinMaskedEdit.EditInfo.CalculateTrueMaxValue() at Infragistics.Win.MonthDropDown.DoDropDown(EmbeddableUIElementBase element) at Infragistics.Win.DateTimeEditor.DoDropDown() at Infragistics.Win.EmbeddableEditorBase.DropDown() at Infragistics.Win.DateTimeEditorDropDownButtonUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities Assembly Version: 9.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities.Sync Assembly Version: 9.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll----------------------------------------Microsoft.VisualStudio.Debugger.Runtime Assembly Version: 9.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll----------------------------------------vshost Assembly Version: 9.0.0.0 Win32 Version: 9.0.21022.8 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpit.vshost.exe----------------------------------------Infragistics2.Documents.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Documents.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Documents.v9.1.dll----------------------------------------Infragistics2.Excel.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Excel.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Excel.v9.1.dll----------------------------------------Infragistics2.Shared.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Shared.v9.1.dll----------------------------------------Infragistics2.Win.AppStylistSupport.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.AppStylistSupport.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.AppStylistSupport.v9.1.dll----------------------------------------Infragistics2.Win.Misc.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v9.1.dll----------------------------------------Infragistics2.Win.SupportDialogs.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.SupportDialogs.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.SupportDialogs.v9.1.dll----------------------------------------Infragistics2.Win.UltraChart.v9.1.Design Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraChart.v9.1.Design/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraChart.v9.1.Design.dll----------------------------------------Infragistics2.Win.UltraGauge.v9.1.Design Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraGauge.v9.1.Design/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraGauge.v9.1.Design.dll----------------------------------------Infragistics2.Win.UltraWinCalcManager.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinCalcManager.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinCalcManager.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinCalcManager.v9.1.FormulaBuilder Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinCalcManager.v9.1.FormulaBuilder/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinCalcManager.v9.1.FormulaBuilder.dll----------------------------------------Infragistics2.Win.UltraWinChart.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinChart.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinChart.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinDataSource.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDataSource.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDataSource.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinDock.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDock.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDock.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinExplorerBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinGauge.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGauge.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGauge.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.DocumentExport.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.DocumentExport.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.DocumentExport.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.ExcelExport.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.ExcelExport.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.ExcelExport.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinGrid.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinInkProvider.Ink17.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinInkProvider.Ink17.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinInkProvider.Ink17.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinInkProvider.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinInkProvider.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinInkProvider.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinListBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinListView.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinListView.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinListView.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinMaskedEdit.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinMaskedEdit.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinMaskedEdit.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinPrintPreviewDialog.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinPrintPreviewDialog.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinPrintPreviewDialog.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinSchedule.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinSchedule.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinSchedule.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinSpellChecker.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinSpellChecker.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinSpellChecker.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinStatusBar.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinTabbedMdi.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabbedMdi.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabbedMdi.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinTabControl.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinToolbars.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v9.1.dll----------------------------------------Infragistics2.Win.UltraWinTree.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTree.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTree.v9.1.dll----------------------------------------Infragistics2.Win.v9.1 Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v9.1/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v9.1.dll----------------------------------------Infragistics2.Win.v9.1.Design Assembly Version: 9.1.20091.1000 Win32 Version: 9.1.20091.1000 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v9.1.Design/9.1.20091.1000__7dd5c3163f2cd0cb/Infragistics2.Win.v9.1.Design.dll----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.21022.8 built by: RTM CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------System.Runtime.Serialization.Formatters.Soap Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------ManagementCockpit Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpit.EXE----------------------------------------ManagementCockpitCommunication Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitCommunication.DLL----------------------------------------ManagementCockpitCommon Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitCommon.DLL----------------------------------------eks.IPServer.2.0 Assembly Version: 1.1.9086.1988 Win32 Version: 1.1.9086.1988 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/eks.IPServer.2.0.DLL----------------------------------------log4net Assembly Version: 1.2.10.0 Win32 Version: 1.2.10.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/log4net.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------ManagementCockpitPluginDefinitions Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitPluginDefinitions.DLL----------------------------------------ManagementCockpitUI Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitUI.DLL----------------------------------------Infragistics.License Assembly Version: 1.0.5005.10 Win32 Version: 1.0.5005.10 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll----------------------------------------eks.Lib Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/eks.Lib.DLL----------------------------------------ManagementCockpitApplication_BusinessPartnerSearch Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitApplication_BusinessPartnerSearch.DLL----------------------------------------ManagementCockpitApplication_CustomerRelationshipManagement Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitApplication_CustomerRelationshipManagement.DLL----------------------------------------ManagementCockpitApplication_PhoneRecognition Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitApplication_PhoneRecognition.DLL----------------------------------------System.Data.DataSetExtensions Assembly Version: 3.5.0.0 Win32 Version: 3.5.21022.8 built by: RTM CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Data.DataSetExtensions/3.5.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll----------------------------------------ManagementCockpitApplication_Reporting Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitApplication_Reporting.DLL----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------ManagementCockpitApplication_Startportal Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/Entwicklung/Kundenprojekte/WKV/ManagementCockpit/Bin/Debug/ManagementCockpitApplication_Startportal.DLL----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
