90
RowSpan in cells
With doing rowspan in the cells of the ultrawingrid in runtime?
(version 2008 v 3)
see the code below:
private void button1_Click(object sender, EventArgs e)
            UltraDataSource uds = new UltraDataSource();
            int totCols = 20;
            for (int c = 0; c < totCols; c++)
                uds.Band.Columns.Add(c.ToString());
            int totRows = 20;
            uds.Rows.SetCount(totRows);
            ultraGrid1.DataSource = uds;
            this.ultraGrid1.CreationFilter = new ColRowSpan();
            ultraGrid1.DisplayLayout.Override.RowSelectorNumberStyle = RowSelectorNumberStyle.VisibleIndex;
            ultraGrid1.DisplayLayout.Override.RowSizing = RowSizing.AutoFree;
            ultraGrid1.DisplayLayout.Override.CellMultiLine = Infragistics.Win.DefaultableBoolean.True;
            ultraGrid1.Rows[0].Cells[0].Value = "Label alfanumérico:";
            ultraGrid1.Rows[0].Cells[0].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.FormattedText;
            ultraGrid1.Rows[0].Cells[0].Appearance.BackColor = SystemColors.Control;
            Infragistics.Win.ValueList list = new Infragistics.Win.ValueList(); // ultraGrid1.DisplayLayout.ValueLists.Add("Booleano");
            list.ValueListItems.Add("SIM", "SIM");
            list.ValueListItems.Add("NÃO", "NÃO");
            list.ValueListItems.Add("OK", "OK");
            ultraGrid1.Rows[1].Cells[0].Value = "DropDownList:";
            ultraGrid1.Rows[1].Cells[0].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.FormattedText;
            ultraGrid1.Rows[1].Cells[1].ValueList = list;
            ultraGrid1.Rows[1].Cells[1].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
            Celula cel = new Celula();
            cel.Codigo = 1;
            cel.Row = 2;
            cel.Col = 0;
            cel.ColSpan = 2;
            cel.Rotulo = "aqui um colspan";
            cel.Tipo = "R";
            ultraGrid1.Rows[2].Cells[0].Tag = cel;
            Celula cel1 = new Celula();
            cel1.Codigo = 2;
            cel1.Row = 3;
            cel1.Col = 0;
            cel1.RowSpan  = 2;
            cel1.Rotulo = "aqui um rowspan";
            cel1.Tipo = "R";
            ultraGrid1.Rows[3].Cells[0].Tag = cel1;
            Infragistics.Win.UIElementViewer.UIElementViewerDialog dl = new Infragistics.Win.UIElementViewer.UIElementViewerDialog();
            dl.Show(this);
public class Celula
        private int nrColuna;
        private int nrLinha;
        private string inTipo;
        private decimal comprCol;
        private decimal alturaLinha;
        private int colSpan;
        private int rowSpan;
        private string rotulo;
        public Celula()
            nrColuna = 0;
            nrLinha = 0;
            inTipo = String.Empty;
            comprCol = 0;
            alturaLinha = 0;
            colSpan = 0;
            rowSpan = 0;
            rotulo = "";
        int codigo = 0;
        public int Codigo
            get
                return codigo;
            set
                codigo = value;
        public virtual int Col
            get
                return nrColuna;
            set
                nrColuna = value;
        public virtual int Row
            get
                return nrLinha;
            set
                nrLinha = value;
        public virtual String Tipo
            get
                return inTipo;
            set
                 inTipo = value;
        public virtual decimal ComprCol
            get
                return comprCol;
            set
                comprCol = value;
        public virtual decimal AlturaLinha
            get
                return alturaLinha;
            set
                alturaLinha = value;
        public virtual int ColSpan
            get
                return colSpan;
            set
                colSpan = value;
        public virtual int RowSpan
            get
                return rowSpan ;
            set
                rowSpan = value;
        public virtual String Rotulo
            get
                return rotulo;
            set
                if (value == null) rotulo = "";
                else rotulo = value;
public class ColRowSpan : Infragistics.Win.IUIElementCreationFilter
       // help.infragistics.com/.../Infragistics2.Win.v8.2~Infragistics.Win.UltraControlBase~CreationFilter.html
        #region Implementation of IUIElementCreationFilter
        public void AfterCreateChildElements(Infragistics.Win.UIElement parent)
        public bool BeforeCreateChildElements(Infragistics.Win.UIElement parent)
            //Declare some variables
            Infragistics.Win.UltraWinGrid.CellUIElement objCellUIElement;
            Infragistics.Win.UltraWinGrid.UltraGridCell objCell;
            Infragistics.Win.UltraWinGrid.UltraGrid grid;
            if (parent is Infragistics.Win.UltraWinGrid.CellUIElement)
                //Get a reference to the cell, and the cells ui element.
                objCellUIElement = (Infragistics.Win.UltraWinGrid.CellUIElement)parent;
                objCell = (Infragistics.Win.UltraWinGrid.UltraGridCell)objCellUIElement.GetContext(typeof(Infragistics.Win.UltraWinGrid.UltraGridCell));
                grid = (Infragistics.Win.UltraWinGrid.UltraGrid)objCellUIElement.GetContext(typeof(Infragistics.Win.UltraWinGrid.UltraGrid));
                int spanWidth = objCell.Width;
                int spanHeight = objCell.Height;
                Celula cel = (Celula)objCell.Tag;
                if (cel != null)
                    //configura o rotulo
                    if (cel.Tipo.ToUpper() == enTipoElemento.R.ToString())
                        objCell.Value = cel.Rotulo;
                        objCell.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.FormattedText;
                        objCell.Appearance.BackColor = SystemColors.ButtonShadow; //SystemColors.Control;
                    //ColSpan
                    if (cel.ColSpan != 0)
                        for (int ifor = objCell.Column.Index + 1; ifor < (objCell.Column.Index + cel.ColSpan); ifor++)
                            Infragistics.Win.UltraWinGrid.UltraGridCell nextCel = objCell.Row.Cells[ifor];
                            spanWidth += nextCel.Width; // calcula o tamanho do span
                            //Oculta as demais celulas fora do span
                            nextCel.Hidden = true;
                        objCellUIElement.Rect = new Rectangle(objCellUIElement.Rect.X, objCellUIElement.Rect.Y, spanWidth, objCellUIElement.Rect.Height);
                    //RowSpan
                    if (cel.RowSpan != 0)
                        for (int ifor = objCell.Row.Index + 1; ifor < (objCell.Row.Index + cel.RowSpan); ifor++)
                            spanHeight += grid.Rows[ifor].Height;  // calcula o tamanho do span
                            Infragistics.Win.UltraWinGrid.CellUIElement cellUI = (Infragistics.Win.UltraWinGrid.CellUIElement)grid.Rows[ifor].Cells[objCell.Column.Index].GetUIElement();
                            if (cellUI != null) cellUI.Rect = new Rectangle(0, 0, 0, 0);
                        objCellUIElement.Rect = new Rectangle(objCellUIElement.Rect.X, objCellUIElement.Rect.Y, objCellUIElement.Rect.Width, spanHeight);
            //Return false to let the grid know we did not handle the event.
            return false;
        #endregion
