I have created a toolbar that includes a TaskPaneTool that references a listbox control to display events. This is similar to the infragistics sample app WinMisc - Ribbon at Runtime.
I have enabled the FloatToolbarFadeDelay so that the floating toobar fades when not used for 500ms. When I move the mouse over the toolbar header it loses transparency and returns to the normal display style - this is expected behaviour.
However, when the toolbar is in a faded state and I move over the listbox in the taskpane the toolbar remains faded even though the events of the listbox can be processed.
Is there an approach I should use to force the toolbar to return to its "active" state when the mouse moves over the child "listbox" control? I have tried the following but the result is not ideal. I have trapped the MouseMove event on the listbox control assigned to the TaskPane and disabled and then re-enabled the toolbar. This forces the toolbar to return to its none faded state although the toolbar can be seen to flicker.
Any ideas would be appreciated.
This could be a bug. I would recommend submitting this to the support group: http://www.infragistics.com/gethelp.
Thanks Mike, will do.
