I have a custom control with toolbar used as context menu. Adding this control to one particular form generates this error when opening the form designer. This does not occur on several other forms using the control. Additionally the form and control run with no problem
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnFormLoad(Object sender, EventArgs e)at System.Windows.Forms.UserControl.OnLoad(EventArgs e)at System.Windows.Forms.UserControl.OnCreateControl()at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)at System.Windows.Forms.Control.CreateControl()at System.Windows.Forms.Control.ControlCollection.Add(Control value)at System.Windows.Forms.Design.ControlDesigner.DesignerControlCollection.Add(Control c)
Help greatly appreciated as it is very time consuming dumping and rem'ing references when designing.
Its hard to say what the problem is just from the callstack. Is there an exception type and/or message displayed? In either case, I would recommend submitting the issue to the support group: http://www.infragistics.com/gethelp.
