I searched all Forum Articles about the maximum height of a cell, if using CellMultiLine Property in combination with RowSizing and RowSizingAutoMaxLines.
But my Problem is, that this Property doesn't work at all. I used several combinations and places to set this property with no effect. If i enter more lines than set in RowSizingAutoMaxLines and use for example AutoFree to adjust the height through doubleclick - all lines in the Cell are expanded for the selected row.
thanks Sebastian
The answer in my case was to have a special Look at RowSizing Property. With the following Settings the AutoMaxLines should work.
ultraGrid.DisplayLayout.Override.CellMultiLine == Infragistics.Win.DefaultableBoolean.True;ultraGrid.DisplayLayout.Override.RowSizingAutoMaxLines = 3;ultraGrid.DisplayLayout.Override.RowSizing = RowSizing.AutoFixed;
